Hello everyone,
RouterBOARD 3011UiAS
6.42.3
I'm using a USB modem HUAWEI E156G, I only need SMS capabilties.
[admin@MikroTik] > /port print
Flags: I - inactive
DEVICE NAME CHANNELS USED-BY BAUD-RATE
0 serial0 1 Serial Console 115200
1 1-1 usb2 2 sms tool 9600
If I send a SMS to my router using my cellphone, I receive it and it's readable in the "inbox", but if I try to send a SMS from the router to my cellphone, after some seconds I get the following:
RouterOS WinBox Error
Couldn't perform action - +CMS ERROR: 500 (unknown error) (6)
BUT, if I do the same thing using the terminal:
/tool sms send usb2
it asks me for the recipient phone number and for the text to send.... and it sends it perfectly right away!
This behavior happens with a carrier... using a SIM CARD from another carrier doesn't show the same problem, and I can regularly send SMS through the GUI.
Anybody have a clue?
Thank you very much!
Nicolo'
