Is there a way to do this
ip firewall nat add chain=dstnat protocol=tcp dst-port=25 action=dst-nat to-addresses=10.0.0.1 to-ports=25
but with a domain name as the dest mail server ?
The only way is to use scripting:
Create the nat rule:
/ip firewall nat add chain=dstnat protocol=tcp dst-port=25 action=dst-nat to-ports=25 comment="SMTP domain redirect"
Create the script:
/ip firewall nat {
:local smtpdomain "smtp.yourdomain.com"
set [find comment="SMTP domain redirect"] to-addresses=[:resolve $smtpdomain]
Then, create a scheduler:
/system scheduler add name="SMTP Domain Redirect" start-time=startup interval=5m on-event="<script name>" disabled=no
Interesting. I will test this out.
