SMTP server and 2 WAN links scenario
Hi!
Is it possible scenario?
I have 2 WAN links, 1 ethernet (wan1) and PPPoE (pppoe1) both with static IPs
In the local network I have SMTP Server on 192.168.1.3
I need the following:
  1. LAN computers use pppoe1 to access Internet
  2. SMTP Server is listeting and recieving incoming connections on both wan1 and pppoe1
I tried to do this but SMTP Server is accessible from outside only by pppoe1
My route table:
#           DST-ADDRESS         PREF-SRC          G GATEWAY         DISTANCE INTERFACE
 0 A S   80.xxx.xxx.0/24       217.xxx.xxx.18   r  217.xxx.xxx.17                    wan1
 1 ADC 192.168.1.0/24         192.168.1.2                                                          lan1
 2 ADC 192.168.2.0/24         192.168.2.1                                                          wan2
 3 ADC 195.xxx.xxx.227/32 87.xxx.xxx.200                                                    pppoe1
 4 A S  217.xxx.xxx.0/24       217.xxx.xxx.18   r 217.xxx.xxx.17                    wan1
 5 ADC 217.xxx.xxx.16/28    217.xxx.xxx.18                                                   wan1
 6 A S  217.xxx.xxx.0/24       217.xxx.xxx.18   r 217.xxx.xxx.17                    wan1
 7 A S  217.xxx.xxx.0/24       217.xxx.xxx.18   r 217.xxx.xxx.17                    wan1
 8 A S  0.0.0.0/0                     87.xxx.xxx.200   r 195.xxx.xxx.227                  pppoe1
NAT rules:
1   ;;; SMTP Server (pppoe1)
     chain=dstnat dst-address=87.xxx.xxx.200 protocol=tcp dst-port=25
     action=dst-nat to-addresses=192.168.1.3 to-ports=25
 2   ;;; SMTP Server (wan1)
     chain=dstnat dst-address=217.xxx.xxx.18 protocol=tcp dst-port=25
SMTP is accessible only from 87.xxx.xxx.200
How can I fix it?
P.S.
192.168.1.0/24 - LAN (ether1)
192.168.2.0/24 - ADSL Modem connected to this network (ether2)
Access for LAN computers
 3   ;;; Access to wan1
     chain=srcnat out-interface=wan1 src-address=192.168.1.0/24 routing-mark=routewan1 action=masquerade
 4   ;;; Access to ADSL modem
     chain=srcnat out-interface=wan2 src-address=192.168.1.0/24 dst-address=192.168.2.0/24 action=masquerade
 5   ;;; Access to pppoe1
     chain=srcnat out-interface=krasnet0 src-address=192.168.1.0/24 action=masquerade
Anybody knows?
Not to be cryptic but - I didn’t see any incoming packet marking in your rules listed above…
Typically, in a case like yours, you would want to mark the incoming connections and packets FROM your two different providers otherwise, and it looks like this is what is happening, the router just picks a route to answer the incoming connetion on…
You may really want to study the loadbalancing docs or take a look at the ones about load balancing on the wiki pages.
Thom
