SNMP 10G interface
Does the dude support 10G interfaces via SNMP. I’m trying to build a link between two non routerOS switches. This is a 10G link. Seems like the dude link type is still using 32bit for speed. Also, is there a way to use the ifXEntry SNMP OID for my port polling instead of the old 32 counters? Running on VM x86 if that makes any difference.
Thank You
