SNMP after Restore
Hello everyone,
I’ve encountered an issue that cropped up after restoring my MikroTik 750Gr3 from a backup. SNMP decided it’s on a hiatus (Timeout: No Response from 10.8.145.1). Restored from a backup with a fully functional setup, I even did a double-check just to be thorough. SNMP is up and running, communities are configured, and the firewall is green-lighting traffic on udp port 161. Packet movement is evident too. However, attempts to access it via Zabbix or ‘snmpwalk’ yield a frustrating “Timeout: No Response from [device]”.
Running firmware version 7.14.3.
Any insights on how to tackle this hurdle?
[Nevian@MikroTik-Gate] /snmp> print
           enabled: yes
           contact:
  engine-id-suffix: F80DAC19322A
         engine-id: 80003a8c04463830444143313933323241
       src-address: ::
       trap-target: 10.8.145.3
    trap-community: rpi2-snmp
      trap-version: 3
   trap-generators: interfaces
               vrf: main
[Nevian@MikroTik-Gate] /snmp> /tool sniffer quick interface=bridge-local  port=snmp
Columns: INTERFACE, TIME, NUM, DIR, SRC-MAC, DST-MAC, SRC-ADDRESS, DST-ADDRESS, PROTOCOL, SIZE, CPU
INTERFACE     TIME    NUM  DIR  SRC-MAC            DST-MAC            SRC-ADDRESS            DST-ADDRESS            PROTOCOL  SIZE  CPU
bridge-local  45.791   20  <-   B8:27:EB:04:FF:7B  18:FD:74:4F:F0:72  10.8.145.3:38721       10.8.145.1:161 (snmp)  ip:udp     106    1
bridge-local  45.792   21  ->   18:FD:74:4F:F0:72  B8:27:EB:04:FF:7B  10.8.145.1:161 (snmp)  10.8.145.3:38721       ip:udp     157    1
bridge-local  45.792   22  <-   B8:27:EB:04:FF:7B  18:FD:74:4F:F0:72  10.8.145.3:38721       10.8.145.1:161 (snmp)  ip:udp     191    1
bridge-local  45.793   23  ->   18:FD:74:4F:F0:72  B8:27:EB:04:FF:7B  10.8.145.1:161 (snmp)  10.8.145.3:38721       ip:udp     189    1
bridge-local  53.247   24  <-   B8:27:EB:04:FF:7B  18:FD:74:4F:F0:72  10.8.145.3:42874       10.8.145.1:161 (snmp)  ip:udp     106    2
bridge-local  53.247   25  ->   18:FD:74:4F:F0:72  B8:27:EB:04:FF:7B  10.8.145.1:161 (snmp)  10.8.145.3:42874       ip:udp     157    3
bridge-local  53.248   26  <-   B8:27:EB:04:FF:7B  18:FD:74:4F:F0:72  10.8.145.3:42874       10.8.145.1:161 (snmp)  ip:udp     189    2
bridge-local  54.249   27  <-   B8:27:EB:04:FF:7B  18:FD:74:4F:F0:72  10.8.145.3:42874       10.8.145.1:161 (snmp)  ip:udp     189    2
bridge-local  55.251   28  <-   B8:27:EB:04:FF:7B  18:FD:74:4F:F0:72  10.8.145.3:42874       10.8.145.1:161 (snmp)  ip:udp     189    2
bridge-local  56.252   29  <-   B8:27:EB:04:FF:7B  18:FD:74:4F:F0:72  10.8.145.3:42874       10.8.145.1:161 (snmp)  ip:udp     189    2
bridge-local  57.253   30  <-   B8:27:EB:04:FF:7B  18:FD:74:4F:F0:72  10.8.145.3:42874       10.8.145.1:161 (snmp)  ip:udp     189    2
bridge-local  58.254   31  <-   B8:27:EB:04:FF:7B  18:FD:74:4F:F0:72  10.8.145.3:42874       10.8.145.1:161 (snmp)  ip:udp     189    2
bridge-local  73.738   32  <-   B8:27:EB:04:FF:7B  18:FD:74:4F:F0:72  10.8.145.3:60520       10.8.145.1:161 (snmp)  ip:udp     189    2
[Nevian@MikroTik-Gate] /snmp> /ip f f p wi
Flags: X - disabled, I - invalid; D - dynamic
 0  D ;;; special dummy rule to show fasttrack counters
      chain=forward action=passthrough
 1    chain=forward action=fasttrack-connection hw-offload=yes connection-state=established,related
 2    chain=forward action=accept connection-state=established,related
 3    ;;; Block Torrents
      chain=forward action=add-src-to-address-list layer7-protocol=torrent src-address=10.8.145.2 address-list=Torrent-Conn address-list-timeout=none-dynamic
      in-interface-list=all log=no log-prefix=""
 4    chain=forward action=drop protocol=tcp src-address=10.8.145.2 dst-address-type="" src-address-list=Torrent-Conn
      dst-port=!0-1023,1723,1194,5555,5900,5800,3389,8728,8291,14147,5222,59905 log=no log-prefix=""
 5    chain=forward action=drop protocol=udp src-address=10.8.145.2 src-address-list=Torrent-Conn
 6    ;;; Block Hackers
      chain=input action=reject reject-with=icmp-admin-prohibited src-address-list=blocked_ip in-interface=internet log=yes log-prefix="banned"
 7    ;;; WAN Protect
      chain=input action=accept protocol=icmp log=no log-prefix=""
 8    chain=input action=accept connection-state=established,related log=no log-prefix=""
 9    chain=input action=accept protocol=udp in-interface=!internet dst-port=53 log=no log-prefix=""
10    chain=output action=accept protocol=tcp dst-address=45.154.73.71 out-interface=N-VPN dst-port=179 log=no log-prefix=""
11    ;;; Drop Invalid Connections
      chain=input action=drop connection-state=invalid in-interface=internet log=no log-prefix=""
12 X  chain=forward action=reject reject-with=icmp-network-unreachable src-address=10.8.145.154 log=no log-prefix=""
13 X  chain=forward action=reject reject-with=icmp-network-unreachable src-address=10.8.145.181 log=no
14    ;;; DDoS Protect
      chain=input action=jump jump-target=detect_DDoS connection-state=new in-interface=internet log=no log-prefix=""
15    chain=detect_DDoS action=return dst-limit=50,50,src-address/1s log=no log-prefix=""
16    chain=detect_DDoS action=add-src-to-address-list address-list=DDoS_black_list address-list-timeout=2h log=no log-prefix=""
17    chain=detect_DDoS action=drop log=no log-prefix=""
18    ;;; LAN Protect
      chain=forward action=accept connection-state=new dst-address=10.8.145.2 in-interface=internet log=no log-prefix=""
19    chain=forward action=accept connection-state=new dst-address=10.8.145.3 in-interface=internet log=no log-prefix=""
20    chain=forward action=accept connection-state=new dst-address=10.8.145.4 in-interface=internet log=no log-prefix=""
21    chain=forward action=accept connection-state=new dst-address=10.8.145.5 in-interface=internet log=no log-prefix=""
22    chain=input action=accept protocol=udp src-address=10.8.145.3 dst-port=161 log=no log-prefix=""
23 X  chain=input action=accept protocol=udp src-address=10.8.145.1 dst-address=10.8.145.3 dst-port=161 log=no log-prefix=""
24    chain=forward action=drop protocol=udp src-address=10.8.145.4 out-interface=N-VPN log=no log-prefix=""
25    ;;; Block WinBox
      chain=input action=drop protocol=tcp in-interface=internet dst-port=8291 log=no log-prefix=""
26    ;;; Block DNS WAN
      chain=input action=drop connection-state=new protocol=udp in-interface=internet dst-port=53 log=no log-prefix=""
27    chain=input action=drop connection-state=new protocol=tcp in-interface=internet dst-port=53 log=no log-prefix=""
