SNMP bug in 4.17
Hi!
I maintain a legacy version of RouterOS in our network, and today I see a little bug with SNMP. I will try to upgrade, to resolv this problem, but inform this to anyone who uses old 4.17 and uses SNMP, is better make some rules in the firewall to close information to out the network.
Even if you configure the community with other value, the public community still available and ready to use. And you can only see this in a terminal. The winbox do not show the public community enabled.
I send a picture attached to this post, to you guys see this bug.
That is very strange. I cannot reproduce that on 4.17 on routerboards. If you delete that entry via terminal, and then hit undo button, does it come back and show under gui ?
No! Always present a error message. I can’t modify any value or delete the entry.
