I have a problem with SNMPv3, it is impossible to change the value for the OID field 1.3.6.1.2.1.1.4.0 - sysContact (RFC1213). I exclude my error because I can change the OID value: 1.3.6.1.2.1.1.5.0 - sysName. I think this is a software BUG.
The problem is that solarwinds checks RW permissions based on the sysContact field. And due to this bug I can’t properly add mikrotik for management.
Do you have any idea how to solve this problem, maybe you can report it as a bug to mikrotik inc.
Unfortunately in solarwinds I can’t change the field for which the authentication occurs. The OID that solarwinds uses is found in the mikrotik logs. Below is the screenshot.
