SNMP community in IP scan
Hi!
How do i set up the SNMP community used in IP Scan? When the scanned machines use ‘public’ their names are visible in the IP Scan window, if not, it isn’t.
Regards,
I dont think this is possible which is REALLY unfortunate. (its hard coded to use “public”)
its so helpful to see that snmp data in mikrotiks great IP scan tool, we have had to start using public as the snmp read-only community (and then blocking all from udp 161 / snmp on Firewall), just so that we can AP names in the ip scan tool.
MT really needs to add a feature wehre we can specify the community /ip scan tool uses.
