snmp crash on ROS 5.17-5.18
hi,
I have a few RB751U-2HnD with similar config. On two of them snmp causes 90% cpu load after some uptime.
tested on 5.17-5.18.
> system resource pr
                   uptime: 4h51m18s
                  version: 5.18
              free-memory: 13984KiB
             total-memory: 29696KiB
                      cpu: MIPS 24Kc V7.4
                cpu-count: 1
            cpu-frequency: 400MHz
                 cpu-load: 100%
           free-hdd-space: 29528KiB
          total-hdd-space: 61440KiB
  write-sect-since-reboot: 3766
         write-sect-total: 244494
               bad-blocks: 0%
        architecture-name: mipsbe
               board-name: RB751U-2HnD
                 platform: MikroTik
> tool profile
NAME                    CPU        USAGE
wireless                all           0%
snmp                    all        91.5%
ethernet                all           1%
console                 all           0%
firewall                all           0%
management              all         2.5%
profiling               all           5%
queuing                 all           0%
bridging                all           0%
unclassified            all           0%
> snmp print
action timed out - try again, if error continues contact MikroTik support and send a supout file (13)
 > snmp set enabled=no
> snmp export
/snmp community
set [ find default=yes ] addresses=0.0.0.0/0 authentication-password="" authentication-protocol=MD5 encryption-password="" encryption-protocol=DES name=public read-access=no security=none \
    write-access=no
add addresses=0.0.0.0/0 authentication-password="" authentication-protocol=MD5 encryption-password="" encryption-protocol=DES name=123456 read-access=yes security=none \
    write-access=no
/snmp
set contact=noc@.ru enabled=yes engine-id=123 location="Spb" trap-community=123456 trap-generators="" trap-target="" trap-version=2
Hi, reset configuration on your RB and change Dude > Settings > Misc > MAC Mapping Refresh Interval (set it to much higher value if you use Dude). I’ve gone through the same with RB751G and it solved the issue.
I do not use Dude
it would be helpful if you could create supout.rif file and send it to support@mikrotik.com at this state using RouterOS 5.18
Ticket#2012062766000927
This issue is resolved?
In Rb532A ( ROS v5.25 ) appears this problem.
