snmp,debug v3 err: 1 not in time window or incorrect engine boots
I have a router that responds as follows to an SNMPv3 request:
What does it mean, and how do I fix it?
Regards,
Graham
What it means is that two or more hosts (in this case routerboards) have the same SNMPv3 engine ID, and net-snmp has mixed up the hosts it has been told to monitor, and is using the engine ID from one router to send requests to another.
In this case you will see one router return SNMPv3 data as normal, and all other routers fail.
To work around the problem, explicitly set the engine-id parameter under /snmp to a unique value (in our case, the name of the router).
