snmp error using CPU heavily
I have an RB433 with eth1 connected to a WAN interface with a static ip address assigned to it. eth2, eth3 and wlan1 are all on a bridge and hotspot is enabled on the bridge. Everything is working well but I have seen that the cpu usage is about 75% usage, when I went into the logs and used debug, this entries just keep coming up non stop.
13:35:58 snmp,debug error: no such name
13:35:58 snmp,debug get .1.3.6.1.2.1.9999.1.1.6.4.1.5.10.10.205.236
13:35:58 snmp,debug get .1.3.6.1.2.1.4.22.1.2.5.10.10.205.123
13:35:58 snmp,debug get .1.3.6.1.2.1.9999.1.1.6.4.1.6.10.10.205.236
13:35:58 snmp,debug get .1.3.6.1.2.1.4.22.1.3.5.10.10.205.123
13:35:58 snmp,debug get .1.3.6.1.2.1.9999.1.1.6.4.1.7.10.10.205.236
Just an update. I do have SNMP enabled on the RB433 I have the permission set to just write. I use this so the dude can see the cpu, disk, etc usage. The ip addresses above are not active in my network but, are in the dhcp scope on the mikrotik, and are not any static addresses on RB433 but once I disable the SNMP the high cpu usage drops to 3%. Thanks for any help.
13:35:58 snmp,debug get .1.3.6.1.2.1.4.22.1.4.5.10.10.205.123
13:35:58 snmp,debug get .1.3.6.1.2.1.9999.1.1.6.4.1.8.10.10.205.236
13:35:58 snmp,debug getnextgetbulk .1.3.6.1.2.1.4.22.1.1.5.10.10.205.123 reps:0 no
I looked up the ip addresses which are 10.10.205.236 and 10.10.205.123 but I don’t see them on the dhcp server entries. Is there a way to block this traffic, I believe this is what causing the high cpu usage. Thanks for the help.
