SNMP error
I have installed routeros x86 on a AIR-RAD2400, basically to run Dude.
The problem is that I can’t enable snmp. When I open a new terminal and I try to enable it with /snmp set enable=yes, appears this message (after 2min or more):
“action timed out - try again, if error continues contact MikroTik support and send a supout file (13)”
Also I’ve tried to export all and I got this report (after a long time)
#error exporting /snmp community
#error exporting
Do you know where the problem is?
Thank you,
