I’m going crazy. Checked all twice and more but I always receive this alert:
casaos@CasaOS:~$ sudo systemctl status snmp_exporter
● snmp_exporter.service - Mikrotik SNMP Exporter
Loaded: loaded (/etc/systemd/system/snmp_exporter.service; enabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Sun 2025-02-16 06:10:54 EST; 5s ago
Process: 70042 ExecStart=/etc/prometheus/snmp_exporter/snmp_exporter --config.file=/etc/prometheus/snmp_exporter/snmp.yml (code=exited, statu>
Main PID: 70042 (code=exited, status=1/FAILURE)
CPU: 42ms
Feb 16 06:10:54 CasaOS systemd[1]: Started Mikrotik SNMP Exporter.
Feb 16 06:10:54 CasaOS snmp_exporter[70042]: ts=2025-02-16T11:10:54.675Z caller=main.go:148 level=info msg="Starting snmp_exporter" version="(ver>
Feb 16 06:10:54 CasaOS snmp_exporter[70042]: ts=2025-02-16T11:10:54.676Z caller=main.go:149 level=info build_context="(go=go1.19.3, user=root@51d>
Feb 16 06:10:54 CasaOS snmp_exporter[70042]: ts=2025-02-16T11:10:54.699Z caller=main.go:157 level=error msg="Error parsing config file" err="yaml>
Feb 16 06:10:54 CasaOS systemd[1]: snmp_exporter.service: Main process exited, code=exited, status=1/FAILURE
Feb 16 06:10:54 CasaOS systemd[1]: snmp_exporter.service: Failed with result 'exit-code'.
