Is it possible to interogate the Oid’s based on a specific result?
Our clients authenticate using radius and open a PPPoE connection with a dynamic IP. Is there a way to pick up their user name then fiter the results so that you can pick up their usageand other information from MT?
I know you can build a static rule to do this but this is no good if the users ID changes.
Regards
Andrew Hooper
