Dear ALL,
I have 2 x router upgraded from v6.49.3 to 7.6 & 7.7, both router SNMP is not work and get the same error.
“timeout while waiting for program 44”
anyone can help?
Tung
Dear ALL,
anyone can help?
Tung
SNMP has timeout, if you are trying to monitor something that could take a lot of time to process, then it will time out, for example large routing tables.
Our CACTI just monitor the interface graph only, any solution?
Same problem - CCR1036 with lot of routes >7m.
Is there a SNMP option to exclude monitoring “large routing tables” or other resources ?
Same Here, CRS326-24S+ v7.7 with all ports connected and peak aggregate bw of 57gbps.
SNMP take long time, and the graphs missing every 3-4 hours.
Solution, increase timeout on CACTI.
Do you have the suggested value on SNMP timeout?
Do you have suggestion?
or will be fix it in further version soon?
I have a similar problem. There are two crs-312-4C after updating RouterOS from 7.3 to 7.8, access via SNMP disappeared on one of the routers. If you turn on Torch on the problematic router and select port 161 for tracking, access via SNMP starts working)
hello,
I’ve noticed the same problem on equipment I use.
I have models of 1072 and 1036 in the environment and after upgrading from RouterOS 6.x to 7.x, SNMP collections every 60 seconds simply break the graph.
Is this already fixed? Can’t seem to find anything in recent changelogs.
