Hi friends. where the OID for mikrotik link down ? I cant find this option. the routeros is 6.46.1
thanks.
Any help ?
Sent from my SM-A705FN using Tapatalk
Depending on the interface number…
On a CCR1036-8g-2s+ the “link-downs” counter for sfpplus1 would be: SNMPv2-SMI::enterprises.14988.1.1.14.1.1.90.1
sfpplus1: SNMPv2-SMI::enterprises.14988.1.1.14.1.1.90.1
sfpplus2: SNMPv2-SMI::enterprises.14988.1.1.14.1.1.90.2
ether1: SNMPv2-SMI::enterprises.14988.1.1.14.1.1.90.3
ether2: SNMPv2-SMI::enterprises.14988.1.1.14.1.1.90.4
ether8: SNMPv2-SMI::enterprises.14988.1.1.14.1.1.90.10
If you need the oid, you can use snmptranslate.
For example:
snmptranslate -On SNMPv2-SMI::enterprises.14988.1.1.14.1.1.90.1
.1.3.6.1.4.1.14988.1.1.14.1.1.90.1
I hope that helps
Thanks for reply
