SNMP monitoring for IPSec tunnel
Hello!
I was wondering if it’s posible to graph trough SNMP the traffic of an IPSec tunnel which has been created trough ip → ipsec → peers. It has no interface, so at the moment i cannot create a graph with SNMP to graph the traffic that goes trough it.
Is there any trick to graph this traffic? or should i configure the ipsec peer using an interface?
Router OS version 6.45.9
best regards!
Ramiro.
In any case, you should upgrade RouterOS to version 6.49.8
