SNMP needs a port to open?
I have an inside* CactieZ server that is a client to my CCR1036 edge router and I also have another outside* CactieZ that lives on Amazon. I want both to be able to connect to my CCR1036 and keep it monitored. What do I need to do in terms of firewall to allow this to open? I had the SNMP ports NATTed to CCR1036 but I had to disable or else my inside CactieZ server would not work.
Thanks,
Maybe if you told us what you did with NAT (exact rule would be good), or generally more about your config…
