Hi Team,
I am new to the group.
I have a query on monitoring Precision Time Protocol on the router OS version 7.8. When I run the command /system/ptp> monitor 0 I get below outputs.
gm-clock-id:
master-clock-id:
slave-port:
offset:
freq-drift:
slave-port-delay:
Can I get these output value from an SNMP monitoring server? I could not find any MIB supporting for these output.
Possible they don’t support the standard PTPBASE-MIB (RFC-8173), or at least not documented as such. Maybe worth a try to load that MIB and use those OID to see.
I can fetch the PTP sync data from the CLI when I put the monitor 0 command. But I want to retrieve the same data from the monitoring server so that I can check any deviation on the time synchronisation.
My device model is: CRS326-24S+2Q
I tried the PTPBASE-MIB (RFC-8173) without luck
I’d file a ticket at help.mikrotik.com to ask (and include supout.rif with it). It may be exposed somewhere else, or it’s a reasonable feature request alternatively.
