SNMP on RouterOS
Then i’m runing on a windows SNMP monitoring from works ok but then i’m runing from a RouterOS SNMP monotoring dont work but if ill do a snmpwalk from local it is vorking but not from server. this is on RouterOS 3.0beta9.
regards
Check the SNMP security settings of the problematic device. Is the Dude server allowed to SNMP probe that device?
the setting of the probed device are in 0.0.0.0/0 so it should not be a problem
I am having same problem, with a RouterOS 3.0beta9 not being able to read SNMP from network devices.
Only information i can read is RouterOS interfaces.
Same config,
2 Dude Servers, Same network.
1- RouterOS 3.0beta9
2- Windows Dude Server 3.06beta
(Same Windows 3.0beta6 Client)
Network map on Windows can read/display SNMP information from network Devices.
Network map on RouterOS can’t read SNMP information from network devices.
Hi, RRC
I have the same problem. When I start Dude server on windows I can get SNMP messages from my four routers, but when I start Dude on RB500 I get only interface TX,RX messages.
I used: RouterOS 3.0rc6 and Dude 3.0beta6
Can any one help.
same here, dude on x86 ROS 3.0rc6 is unable to read any SNMP info. Ordinary dude app is reading it without problem.
LePiaf
