snmp security... private or authorized?
It would be helpful if someone knows the difference between using one of these two kind of snmp security… as it doesn’t appear in the 3.0 on line manual yet, thanks
where did you find it? =)
In RouterOS v3.7:
[admin@MikroTik] /snmp community> set public security=[ TAB ]
authorized none private
anyone knows the difference between private and authorized?¿?
oh… try google for SNMP v3 security model
hi, any chance MT could update the manual with info on the snmp “security” setting (none, authorized, private):
https://wiki.mikrotik.com/wiki/Manual:SNMP
read-access (yes | no; Default: yes)	                     Whether read access is enabled for this community
security (authorized | none | private; Default: none)
write-access (yes | no; Default: no) 	                     Whether write access is enabled for this community. Read more >>
I have googled this as suggested, and not finding anything related to snmp v3 and Authorized, none or private in the context of v3 “security”
tks
+1 Yes, please update documentation. (It’s not really a wiki if it can’t be fixed.)
I want to know what this feature does and what security implications it has.
For SNMPv3:
none - no hashing nor encryption
authorized - hashing
private - hashing and encryption
So for none, you dont need hash or encryption password, just username.
SNMPv3 with “none” security behaves much like SNMPv2c.
Authorized will use SHA1 or MD5 (depending on your configuration) hash as the authentication mechanism.
(together with username)
Private will additionaly encrypt the payload - so all SNMP data will be encrypted.
This will of course have a performance hit on the device CPU.
BTW, this is SNMP standards-based stuff, not MikroTik-centric.
So if you research SNMP, you would find all of this.
