SNMP server in ROSv5 responds from different ip than request
Apparently in ROSv5 (5.2 is what I am currently on) the SNMP server will respond from the IP address of the nearest interface. Previous versions of ROS do not function this way and it is causing issues with my firewall rules. Has anyone else encountered this and is there any fix on the horizon?
Thanks!
-Eric
Eric, thank you very much for the report.
We are working on the fix for the problem, it will be included to RouterOS v5.3
