SNMP set support
I`m currently using a Cisco 2960s switch where i disable two ports using SNMP from time to time (using HomeAssistant) the ports are used by the kids to play with IP Telephones.
Does SWos support SNMP set or write? The switch i`m using is a CRS328-24P-4S+RM
I also don’t understand why MikroTik still can’t implement the simplest function — enabling and disabling ports via SNMP. It’s 2026, and not having such a capability is abnormal.
