SNMP Setting
How to set the SNMP setting in Mikrotik, i would like to configure the prtg graph for that SNMP setting shoul be enabled in mikrotik.
How to do that?
from winbox:
ip → SNMP → enable
Thanks for your reply.
Can you pls explain, what was Trap target? Is that should be the same IP which was in mikrotik wan interface(port A) ?
you do not need to mentioned anything there, just enable SNMP and leave other fields empty or disabled.
Is that fine?
yes this should works fine, if you wants you can add contact info and location too.
So what are the trap targets and snmp communities for? Do these have to be setup to interface with The Dude?
