SNMP traps and set
I did a search through the forum for this topic and found some that were asked over 2 years ago. Can this version, 3.4, receive traps from an SNMP device? Also is the SNMP set available in this version.
I don’t know about traps but I saw people were talking about using an external program to do the snmp set from the tools menu. I have not tried either, both would be nice if they were just supported.
Can you please point me to the posts where the SNMP set can be used using an external program. I searched the forum but could not find anything.
Still, anyone else have any word on Trap support?
Hey RTB,
This should help a little… I am curious what are you trying to use SNMPSET for?
http://www.elifulkerson.com/articles/net-snmp-windows-binary-unofficial.php
I have never used it but snmpset.exe should be easy to configure as a tool but supplying the string could be difficult or an external to do things like change the password on ever box :slight_smile:. I figured your search of the forum was complete enough so I took to google.
It would be extremely slick if you could get the tool to put up a box for the string you want to set. :slight_smile: Be careful hehe
SD
