I tried to monitor my clients using snmp with radius manager with ubnt and mikrotik access points but I got no results any ideas ho to make radius manager reads the clients information please ![]()
The SNMP feature in radiusmanager hasnāt worked since Ubiquiti 5.5.x firmware.
I contacted Victor to see if he could work on it but unfortunately, he said he did not have time to fix it so who knows if itāll ever work again.
how I can contact victor ?
Viktor:
support@dmasoftlab.com
I saw that DMASoft is testing 4.2.0. I asked them will they fix ubnt snmp, and I am waiting for answer. Can anyone suggest any alternative to radiusmanager? I am testing bliss radius, but I donāt like it so far ![]()
I can tell you I had him āViktorā install the 4.2 upgrade recently.
DO NOT let him do it, just donāt do the upgrade.
Everything (most critical configs) will revert to ādefaultā config.
I had to find all my backups and re configure everything in RM.
NOT GOOD! His support is *(&^ed up
What do you like to monitor?
Traffic data? When clients login?
I do use Splunk to monitor when user logs inn, traffic data + much more.
Since clients does not login using username/password, I have set DHCP lease to looong time.
Then I can monitor the IP and also add static DNS to make it simpler to see who is who.
More info here: http://forum.mikrotik.com/t/tool-using-splunk-to-analyse-mikrotik-logs-3-3-graphing-everything/121810/4
