I am a customer of an ISP, but I am also helping them with their network. My connection goes thru a Mikrotik router. Is it possible to connect to the ISP’s network to monitor it thru SNMP? I have enabled it on the few of the devices, but so far the only one I can connect to thru SNMP is my own router. I am using SNMP Tester to see if the connection can be made. So far I am being told no response from the devices in the ISP’s network. Is there any way to make this work, or do I need to be connected directly to the ISP’s network?
As long as your router does not actively block udp port 161, and the ISP has opened for you IP to read SNMP, it should work.
From linux i do use this;
snmpget -v2c -c public 192.168.10.1 1.3.6.1.2.1.1.1.0
iso.3.6.1.2.1.1.1.0 = STRING: "RouterOS RB750Gr3"
So my RouterOS respond with RB750Gr3
You should the be able to do:
snmpget -v2c -c public your-isp-ip 1.3.6.1.2.1.1.1.0
If you look at my Splunk project here: http://forum.mikrotik.com/t/tool-using-splunk-to-analyse-mikrotik-logs-3-3-graphing-everything/121810/1
you will see that I found it better that RouterOS gives me traffic counter using local script and syslog,
instead of read traffic counter using SNMP.
This way, I can add as many router to my system, with same script configured without need to tell my Splunk
to monitor this and that.
Thanks for the info.
For everyone, I have a question that is half rhetorical half serious. Does it ever end? Having to learn new software to make things work as they are suppose to?
