Hi!
Who knows how I can use snmpget to obtain the signal strength of a unit?
Regards,
Evert
Hi!
Regards,
Evert
[admin@AP] interface wireless> print oid
Edgars
Yeah, I did find that one… ![]()
But then why doesn’t the following work?
snmpget -v 1 -c [COMMUNITY_STRING] [IP_ADDRESS] .1.3.6.1.4.1.14988.1.1.1.1.1.4.4
snmpwalk does work on those devices…
Regards,
Evert
Hmm, I now have 1 unit on which it works.
The only difference:
non-working units: RouterOS 2.8.5
working unit: RouterOS 2.8.11
Is there somewhere a (detailed) ChangeLog of RouterOS available…?
Regards,
Evert
I think I’ve located the problem…
I have tested a unit with, and a unit without a license key. On both I’ve done ‘interface wireless print oid’
Then I did ‘snmpget -v 1 -c public [IP_address] [OID]’
The licensed unit returned:
Timeout: No Response from [IP_address].
The unlicensed unit returned:
SNMPv2-SMI::enterprises.14988.1.1.1.1.1.4.4 = INTEGER: -56
Can I conclude from this that when I get a license for a unit I actually lose some functionality…?!? ![]()
Regards,
Evert
SNMP works with no matter what license, so this shouldn’t be possible. can you send a supout.rif file from the not working router to support@mikrotik.com ?
update: the problem has been confirmed and will be fixed in the next release. ![]()
update to the update: I was told the problem would be fixed in the next release (which would be 2.8.13), but the ChangeLog entry for 2.8.13 says:
What’s new in v2.8.13:
*) fixed problem - PPTP and PPPoE Windows client could disconnect
after about 15 minutes;
*) fixed bridge after reboot proxy-arp problem;
*) fixed crash when bridging fragmented VLAN packets;
So I guess the fix for this will have to wait until 2.8.14…? ![]()
