I don't know, where I am doing mistake, but my post is still without answer from mikrotik guys
Please, Can You give me some answer to post bellow line. It is important for me to know, if or when this bug will be solved.
p.s. at this moment I got same results with RouterOS v 6.37rc12
Many thanks
With Kind Regards
Martin
I'm trying to test this release and it worked, but I am afraid, that if superchannel option it will be still available, that is it same as DFS-mode=none. For meaningfull use of this feature, must be superchannel feature removed, I think. By the way, radar detecting function working fine. If radar is present in the antenna direction, that is detected and radar channel isn't used for exact time and use next free frequency channel.
But I still get problem with wireless snooper via console, if I run command:
[admin@MikroTik] /interface wireless> snooper snoop wlan1
CHANNEL USE BW NET-COUNT NOISE-FLOOR STA-COUNT
5560/20/a/DP 0% 0bps 0 -111 0
5580/20/a/DP 0% 0bps 0 -111 0
5600/20/a/DP 0.1% 8.8kbps 1 -112 1
5620/20/a/DP 0% 0bps 0 -112 0
-- [Q quit|D dump|C-z pause|n networks|s stations|down]
and press s I can see station, but without used frequencies
Flags: A - active, N - access-point
FREQ ADDRESS SIG SNR OF-FREQ OF-TRAF BW SSID
0 AN 00:1E:DA:EE:AE:DA -92 20 0% 50% 4.5kbps XXXXXXX
1 A 00:0C:42:7A:C9:BD -90 22 0.2% 8.2% 8.0kbps
2 A 4C:5E:0C:84:ED:99 -90 22 1.3% 46.8% 50.1kbps
3 A 4C:5E:0C:82:6D:E1 -85 27 0.2% 9.8% 9.6kbps
or if I press n as networks list is still without frequencies:
FREQ ADDRESS SSID STAS OF-FREQ OF-TRAF BW
0 AFB 00:1E:DA:EE:AE:DA XXXXXXX 1 0.1% 100% 9.2kbps
I think, that it worked fine in version 6.19. In column FREQ was frequency presented s ie. 5600MHz, now values are missing, but we are using this for getting automatic information about frequencies of clients and APs. Now we are without this information due this small bug.
Many thanks for solved this.
Martin
