Hi
The wireless snooper functionality allows the option to scan and filter by frequencies, stations or networks if used from winbox, or terminal by pressing the “s” key for stations “f” for frequency or “n” for networks
However, if it is called from a script, it is not possible to carry out this filtering since a key cannot be “pressed” from a script, so the result is a scan without the detail of networks or stations, since the by default shows data by frequency.
Using the flat-snoop functionality, a scan can be made with the details of networks and stations and exported to a file, but the scan returns a very large file that cannot be treated later as a variable from the mikrotik.
Any solution to obtain snooper filtered result by script, for example for neighboring networks and the % of frequency utilization for each one?
