snooper tool - manual please!
Has anybody any idea on what the ‘snooper’ tool in winbox is actually telling us?
And what the different pictograms mean?
If I snoop against my own network I see that snooper gives the same picto to either a cpe or an AP.
But other units get another sign.
Than I see some trapped level units. Does this mean cpe connected to AP? Makes no sense because some have even 3 levels…
There is this column “Networks”. But its either “0” or nothing mentioned on my own MT-ROS routerboard driven network???
Same for the column “Stations”. Only one of my AP’s is showing the correct no. of stations… but the rest is showing nothing or “0”?
I think it can be a great tool, if it at least was documented…
I have the same question.
I’m trying to use snooper via CLI and save the results to a file or syslog
/interface wireless snooper snoop wlan1 interval=00:00:01.000 append file=wifitest1
In Winbox you can select display: all/stations/frequencies/networks
Can you select this on the CLI ?
You can define: Interval – 00:00:00.020..00:00:05 (time interval)
I assume that this is something like the duration parameter with the wireless scan
http://forum.mikrotik.com/t/help-with-retrieving-interface-wireless-scan-data/40099/1
scan works but gives me not the needed information. Snooper via winbox does but now how do i get these results to a file or syslog or ..
I didn’t manage to get it working.
A kind of manual or some suggestions how to realise this would be of great help.
thanks in advance
Gerard
Anyone getting this work out, I’m looking this as well. Please
Well, as you can see on the data of my first post, its been a while. But never got an answer though…
