SNR or Signal-Strenght ??
To keep a radio cell with the highest quality is better reference values “Signal-Strength” or “SNR” value for connect new users to the cell?
Example with R52
1 - A user with noisefloor:-105 and signal-strength -85 (20dB SNR) is a good value?
2 - User with noisefloor: -93 and signal-strenght -73 (20dB SNR) is a good value?
3 - User with noisefloor: -88 and signal-strenght -73 (15dB SNR) is a good value?
Another question:
Tx/rx rate(54Mbps, 48Mbps, 36Mbps, etc..) change with the change of SNR or what else?
We used to have it around 30 SNR, no matter that weird ROS RSSI show to us. :wink:
