SNR -ve but ccq's around 75% on 5.8Ghz link.
I have one link which recently has started producing some weird numbers,
I think because of adjacent interference. The tower site is very RF busy, with FM/AM/Aeronautical/Everything sources… Another user has had
interference between 3pm and 5pm in the afternoons on their 5ghz link
but that effect doesnt show on ours..
The tower end looks like this
0 interface=wlan1 radio-name=“xxx-xxx-xxx” mac-address=00:02:6F:22:FB:D7 ap=no
wds=no rx-rate=24Mbps tx-rate=24Mbps packets=2844647,2863248
bytes=1604633708,483278664 frames=2844647,2867149
frame-bytes=1587589232,466138261 hw-frames=2844656,2867159
hw-frame-bytes=1655868599,534950097 uptime=2w12h13m46s last-activity=190ms
signal-strength=-81dBm@24Mbps signal-to-noise=-3dB
strength-at-rates=-80dBm@6Mbps 17h39m41s180ms,-79dBm@9Mbps 2w8h37m51s160ms,-
80dBm@12Mbps 2w2h29m33s530ms,-83dBm@18Mbps
1w1d20h39m7s220ms,-81dBm@24Mbps 190ms
tx-signal-strength=-64dBm tx-ccq=70% rx-ccq=73% p-throughput=21112
ack-timeout=45 distance=45 nstreme=no framing-mode=none
routeros-version=“2.9.17” last-ip=202.182.135.70 802.1x-port-enabled=yes
authentication-type=none encryption=none compression=no
monitor
status: running-ap
band: 5ghz
frequency: 5765MHz
noise-floor: -78dBm
overall-tx-ccq: 68%
registered-clients: 1
authenticated-clients: 1
current-ack-timeout: 45
current-distance: 45
nstreme: no
current-tx-powers: 6Mbps:16,9Mbps:16,12Mbps:16,18Mbps:16,24Mbps:16,
36Mbps:15,48Mbps:14,54Mbps:13
notify-external-fdb: no
The other end is fine.
0 interface=wlan1 radio-name=“xxx-xxx-xxx” mac-address=00:02:6F:22:FB:DA ap=yes
wds=no rx-rate=24Mbps tx-rate=24Mbps packets=2867649,3022521
bytes=483352307,1620003394 frames=2867649,3026423
frame-bytes=466169843,1601926718 hw-frames=2867649,3026432
hw-frame-bytes=534993419,1674561104 uptime=2w12h16m57s last-activity=50ms
signal-strength=-64dBm@6Mbps signal-to-noise=35dB
strength-at-rates=-64dBm@6Mbps 80ms,-64dBm@9Mbps 2w11h44m15s,-63dBm@12Mbps
2w8h56m24s110ms,-63dBm@18Mbps 2w7h25m6s370ms,-
64dBm@24Mbps 50ms
tx-signal-strength=-81dBm tx-ccq=75% rx-ccq=72% p-throughput=19943
ack-timeout=46 distance=46 nstreme=no framing-mode=none
routeros-version=“2.9.17” last-ip=202.182.135.110 802.1x-port-enabled=yes
band: 5ghz
frequency: 5765MHz
tx-rate: 24Mbps
rx-rate: 24Mbps
ssid: “xxxxxxxxxxxxx”
bssid: 00:02:6F:22:FB:DA
radio-name: “xxxxxxxxxxxx”
signal-strength: -64dBm
tx-signal-strength: -82dBm
noise-floor: -99dBm
signal-to-noise: 35dB
tx-ccq: 75%
rx-ccq: 76%
p-throughput: 20017
current-ack-timeout: 46
current-distance: 46
wds-link: no
nstreme: no
framing-mode: none
routeros-version: “2.9.17”
last-ip: xxxxxxxxxxxxx
802.1x-port-enabled: yes
authentication-type: none
If the SNR is -3db which is correct based on a noise floor of -78db and a signal strength of -81db how come the links working at all let alone with
ccq’s of around 75%.. The Tx signal strength is also showing on the town
end maybe that attenna has shifted, but how come the link works ok..
Looking at your tower site it has a noise-floor: -78dBm and then your remote station says it has a transmit strenth of tx-signal-strength: -82dBm.
I would suggest that is why you are having some outages.
How to fix? I’m not too sure I am having a simular issue. You can try some noise filters on your coax at the relay site. Better antani, directional antani’s. or some type of antani that has a backing to it (tto cut off the singals to the rear of it).
-Michael
