After latest discussions about NV2 quality for a Point to Point link, is it still the best protocol to be used ?
Thank you
Personally don’t like using nv2 for ptp since the latency is usually higher, I prefer nstreme and have had the most success using it.
Should be easy to switch from either of the 3 protocols and do a few tests to see which perform the best for your situation.
