so where is the problem with Nstreme
ofcorse something below is NOT compatible with nstreme please tell me what it is.
2 MT's one at 2.9.51 one at 3.10
one in AP , one in AP with a WDS bridge to the other router. (to make it a repeater)
Using WEP aes-ccm (since that is ALL That works with WDS bridges, not wpa)
I turned on Nstreme on both sides...no connection, no messages in either logs.
so i turned OFF encryption on BOTH sides..then turned on nstream on both sides...no conneciton, no log messages.
-64 RSSI on both sides..great link.
You can not establish nstreme AP-to-AP links, you have to use station-wds on one side in order to do WDS in nstreme network.
jo2jo -
I have never seen nstreme work with WDS…
You are probably going to have a difficult time having ROS 3.10 and ROS 2.9.51 connect via nstreme as well… There are some differences between the ROS 2.9.51 and 3.10 versions.
