i am experiencing problems using a RB44GV into a Soekris 5501-70 board with R3.30
My setup is 2x1Gbps links between the Soekris via RB44GV to RB1000 in a balanced-rr/mii-type1 bonding grup.
What happens is that whenever i try to do a bandwidth test, the Soekris board crashes after a few megabytes transmitted.
This does not occur if i am using the onboard fast ethernet interfaces of the 5501-70.
it does not crash with the onboard cards (also VIA) nor does it crash with a single port gigabit card (intel chipset) i had handy for testing.
It only crashes when im using the quad gigabit card in the pci slot.
I did enable logging to internal file, but there’s nothing in that log that would explain this, also i belive that enabling external logging wont do much good, as the box crashes and no ip packets are being sent out afterwards.
Otherwise, the 5501 performs ok under load, no crashes.
