i have few softphones. Each softphone has his own sip account from internet voip provider. we need to prioritize voip traffic in both directions (from softphones to provider sip server and from provider sip server to the softphones). What is the easiest and best way to accomplish this?
From you → provider If you’re using windows:
-Mark the packets for the softphone application with a DSCP marking (windows QoS scheduler policy). This can be done via group policy or local computer Policy.
Computer Configuration → Windows Settings → Policy Based QoS → <insert policy, specify executable and relevant TCP/UDP ports as required and specify DSCP value>
-Create mangle rules in ROS to mark the packets with the DSCP tag set in the policy
-Create appropriate queues.
From Provider → you
If DSCP is available, mark on that if not, use the providers IP address
can you provide me config of mangle and queue? Instead of DSCP can i prirotize traffic from me to our provider based on dst address? Like for the incoming traffic (src traffic), srd/dst is provider address
if i do mangling, and after queue tree WITHOUT MAX-LIMIT and LIMIT-AT will my mark traffic be prioritize? Janis Megis said in his presentation that if there is no that two thing configured priritize will not work because MKT is not doing prioritize, it must know what is the bandwith limit so that it can drop traffic with lower priority, otherwise there is no any action.
i did something, can someone check my config to see if this is ok?
ether1=LAN
ether2=WAN
x.x.x.x ip address of sip voip provider
The goal is to reserve at least 500kbps for voip traffic (for about 5 simultaneous calls) from client to provider and vise versa. Will this code do the trick? If not please provide the correct one.
Client softphone are marking sip and rtp with DSCP 40 so i mark that traffic with dscp value in mangle and traffic from other direction i marked with source ip (voip provider ip address).
