Software compresion
How can I enable software compresion for the VPN connection?
Greetings: René.
Edit the profile used by your VPN interface under “/ppp profile”. Either set “Use Compression” or “Use VJ Compression” depending on what compression you want to use.
http://wiki.mikrotik.com/wiki/Manual:PPP_AAA#Properties
