I have a Rb951ui-2hnd + 2x SMA connectors + 2x 10dbi Antennas
I want to solder sma cables to the routerboard but i don’t know where should i solder that.
Could you please help me tho do that?
Normis will not definitely help with this. Search the Google, there are pictures that could inspire you, but expect that you will just damage the device. Rather buy appropriate device or parts instead and build what you need from the blocks…
I have soldered pigtails but i don’t see any change and effect in the wireless quality.
It is as the first time.
Should i do any settings in the router options? ( enabling Chains or… )
10 dbi omni antennas for indoors are worse than 5dbi. I solder pigtails and used 5dbi with excelent results. Signal was better with exactly 3dbi. Also if you didn’t know from the start which are the antennas, it is a good chance you also did not do a very good solder job.
A bit late my answer, but I found in some topic sometime ago that those soldered connectors for wifi are MS156 (not U.FL) .
( http://forum.mikrotik.com/t/new-rb951g-2hnd/62756/45 )
U can get a pigtails/adapters to any other connector (SMA/etc…) on aliexpress
