If you have a solidMOUNT to hand on your desk or workbench would you be kind enough to measure the dimension between the 4# fixing hole centres in #mm on the plate that faces onto the rear of the antenna, e.g. an LHGG etc.
I have a solidMOUNT but it’s at the top of a mast and I’m hoping to use another to mount a third party antenna. I’ve looked around MT & the internet but haven’t spotted what I require.
Let’s see if I can remember to check when I get home. I have one in the box in the garage - and I even know where it is!
If I don’t respond in the next 18 hours, reply to this thread and I will get an E-Mail which should remind me.
