solve db in 6.36
Hi every body
iam install the dude server 6.37rc10 and work to the dude client >>> the problem when i install the dude server 6.36 packge in the ccr1016 and import the db from 6.37rc10 the dude client 6.36 dont work show me theis error failed connect:10061
soory >> iam in iraq my english not very good :confused:
some pic to show my problem
thank u
It is simple, database from new version 6.37rc is not compatible width old version.
Look here http://forum.mikrotik.com/t/the-dude-v6-37rc-test-builds/100037/1
Downgrade to older versions wont be possible from v6.37.
thank bro
can the sppuort change the virsion from 6.37rc10 to 6.36
We can’t. Best option if you want to use v6.36 then best option would be to just use older backup if you have one.
