I have 2 wans, and I want use one only for http traffic, and the other WAN for the rest of traffic.
First I made a connection mark, packet mark, and route mark for 80 TPC port.
After, I mark the rest of traffic (connection, packet and route). It seems very simple: (
I don't know how resolve it, I read and read and tried a lot of options...please help
The configuratión es very simple, What is wrong or missing?
// MASQUERADE
add action=masquerade chain=srcnat disabled=no out-interface=public1 src-address-list=10.0.0.0/24
add action=masquerade chain=srcnat disabled=no out-interface=public2 src-address-list=10.0.0.0/24
// DHCP CLIENT
/ip dhcp-client
add disabled=no interface=public1 use-peer-dns=yes use-peer-ntp=yes
add disabled=no interface=public2 use-peer-dns=yes use-peer-ntp=yes
(I try with default_route=yes also)
// MANGLE
/ip firewall mangle
add action=mark-connection chain=prerouting connection-state=new disabled=no dst-port=80 new-connection-mark=Wan02_con passthrough=yes protocol=tcp
add action=mark-packet chain=prerouting connection-mark=Wan02_con disabled=no new-packet-mark=Wan02_mark passthrough=yes
add action=mark-routing chain=prerouting connection-mark=Wan02_con disabled=no new-routing-mark=Wan02_Route passthrough=no
add action=mark-connection chain=prerouting connection-state=new disabled=no new-connection-mark=Wan01_con passthrough=yes
add action=mark-packet chain=prerouting connection-mark=Wan01_con disabled=no new-packet-mark=Wan01_mark passthrough=yes
add action=mark-routing chain=prerouting connection-mark=Wan01_con disabled=no new-routing-mark=Wan01_Route passthrough=no
// ROUTE
add check-gateway=ping disabled=no distance=1 dst-address=0.0.0.0/0 gateway=192.168.0.1 pref-src=192.168.0.104 routing-mark=Wan02_Route scope=30 target-scope=10
add check-gateway=ping disabled=no distance=1 dst-address=0.0.0.0/0 gateway=93.156.56.254 routing-mark=Wan01_Route scope=30 target-scope=10
/ip route rule
add action=lookup disabled=no interface=public1 routing-mark=Wan01_Route table=Wan01_Route
add action=lookup disabled=no interface=public2 routing-mark=Wan02_Route table=Wan02_Route
(PRINT OF ROUTES)
DST-ADDRESS PREF-SRC GATEWAY DISTANCE
0 A S 0.0.0.0/0 192.168.0.104 192.168.0.1 1
1 A S 0.0.0.0/0 93.156.56.254 1
2 ADC 10.0.0.0/24 10.0.0.1 bridge 0
3 ADC 93.156.56.0/21 93.156.57.178 public1 0
4 ADC 192.168.0.0/24 192.168.0.104 public2 0
