SOLVED: Adding wlan to VLAN aware bridge 6.41rc56
Greetings, dear forumers! This is my first post in your forum.
After a couple of days worth of trying to learn the MikroTik-way, I have the hAP up and running fine with VLANs in the new VLAN aware bridge. Firstly; the new VLAN aware bridge is way better than the switch or old bridge, coming from a Cisco/HP world. I do only switching and 1 management IP on the hAP.
The problem now is that I want the wlan added to the bridge. I am now using a work-around(?) with a separate bridge for wireless, config as follows:
add fast-forward=no name=bridge-wl
Side note: I assume fast-forward is not nessecary when just switching?
add bridge=bridge-wl interface=VL78 pvid=78
add bridge=bridge-wl interface=wlan2-5ghz pvid=78
add bridge=bridge-wl interface=wlan1-2ghz pvid=78
Vlan78 being vlan interface on ether1 (my upstream trunk-port).
This works, but I would assume it’s not the right way in version 6.41rc56? I have tried a number of configs where I added the wlan1+2 in the “main” bridge and tried tagging and untagging everywhere, but never would the packets go out the trunk (ether1, vl78).
Here is my bridge/bridge port/bridge vlan config in full:
add fast-forward=no mtu=1598 name=bridge-wl
add igmp-snooping=yes name=bridge1 vlan-filtering=yes
add bridge=bridge1 interface=ether1 pvid=78
add bridge=bridge1 interface=ether2 pvid=78
add bridge=bridge1 interface=ether3 pvid=78
add bridge=bridge1 interface=ether4 pvid=78
add bridge=bridge1 interface=ether5 pvid=3752
/interface bridge vlan
add bridge=bridge1 tagged=ether1 vlan-ids=116
add bridge=bridge1 tagged=ether1 untagged=ether2,ether3,ether4 vlan-ids=78
add bridge=bridge1 tagged=ether1 untagged=ether5 vlan-ids=3752
I hope someone can either tell me I’m doing it the right way, or help me out - I’ve googled as deep as I think I can!
I did a boopie.
It seems it works fine adding the WLAN just as with ether-ports. The problem is that I had activated a vlan interface under the ether1 - which stopped the bridge from being able to use that vlan.
Why I am not sure, I assume there is some logic to it. Then again, I guess I have to add management IP on the bridge instead of the VLAN then, as I cannot make an interface vlan without breaking the bridge…If anybody has an idea about this, please let me know.
