i Forum
I’ve just got a new Line from ISP with a /29 IP Range
I can only get traffic through on my main IP 5.103.38.98 - → not on X.99 X.100 etc
The ISP says that the arp-request beeing rejected - How do I fix this so I can use alle IP addresses and forward the designated traffic to this different IP
I’m going to have several servers dedicated to different public IP - but as far as now the request are not comming through - Only on the main IP - wich is set on the router.
[admin@Hercules] /interface ethernet> print
Flags: X - disabled, R - running, S - slaveNAME MTU MAC-ADDRESS ARP MASTER-PORT SWITCH
0 R ;;; DMZ Network
DMZ 1500 4C:5E:0C:03:39:0A enabled none
1 R ;;; WAN Network
WAN 1500 4C:5E:0C:03:39:0B enabled none
2 RS ;;; LAN Network
ether1 1500 4C:5E:0C:03:39:04 enabled none switch1
3 S ether2 1500 4C:5E:0C:03:39:05 enabled none switch1
4 S ether3 1500 4C:5E:0C:03:39:06 enabled none switch1
5 S ether4 1500 4C:5E:0C:03:39:07 enabled none switch1
6 ether5 1500 4C:5E:0C:03:39:08 enabled none
7 ether6 1500 4C:5E:0C:03:39:09 enabled none
8 sfp-sfpp… 1500 4C:5E:0C:03:39:02 enabled none
9 sfp1 1500 4C:5E:0C:03:39:03 enabled none[admin@Hercules] /ip arp> print
Flags: X - disabled, I - invalid, H - DHCP, D - dynamic, P - published,
C - completeADDRESS MAC-ADDRESS INTERFACE
0 DC 172.16.10.50 C0:3F:D5:6B:BA:B4 DMZ
1 DC 172.16.0.30 00:09:34:2D:17:9C Bridge-LAN
2 DC 5.103.38.97 00:08:AE:8C:C8:C0 WAN
3 DC 172.16.10.120 B8:AE:ED:EB:46:91 DMZ
4 DC 172.16.0.6 54:EE:75:61:FC:05 Bridge-LAN
5 DC 172.16.0.47 E4:9A:79:67:1E:7B Bridge-LAN
6 DC 172.16.0.168 74:81:14:3B:10:3E Bridge-LAN
7 DC 172.16.10.150 00:11:32:32:42:69 DMZ
8 DC 172.16.0.9 44:D9:E7:F9:05:D2 Bridge-LAN
9 D 172.16.0.132 Bridge-LAN
10 DC 172.16.10.99 1C:98:EC:0F:8C:DC DMZ
11 D 172.16.10.8 DMZ
12 DC 172.16.10.110 C0:3F:D5:61:1E:7C DMZ
13 DC 172.16.0.26 E8:5B:5B:91:5C:5F Bridge-LAN
14 DC 172.16.0.21 B8:27:EB:68:4F:B3 Bridge-LAN
15 DC 172.16.0.226 EC:59:E7:4A:32:70 Bridge-LAN
I’ve google this but cannot seem to find anything regarding this problem - so please help with this problem
Solution:
All adresses should be added as seperate IP
add address=5.103.38.102/29 disabled=no interface=WAN network=5.103.38.96
