Here’s what I learned and what worked for me. MANY THANKS to folks on the Mikrotik forum and the r/mikrotik subreddit for their help.
I set this up successfully on 3 routers, hAP ac, RB 951, CRS 125: These have a switch chips which are VLAN aware. You can assign a switch port to a VLAN and get wire speeds. No setting PVIDs or bridge VLAN filtering needed. I did this at the Terminal command line, but you may be able to do this from Winbox.
I followed guides at
https://help.mikrotik.com/docs/display/ROS/Basic+VLAN+switching
and
https://help.mikrotik.com/docs/pages/viewpage.action?pageId=103841836
For the hAP ac, here’s my setup:
My Home Automation (HA) device I want to join VLAN30
hAP ac: HA device connected to ether 5. Ether 1 trunks all traffic to Router.
RB4011 router: All VLANs are defined and routed here. Ether1 is WAN, Ether2-8 are LAN. All other VLAN30 HA devices are connected to the LAN here. hAP ac ether1 connected to a LAN port.
This worked for me: Starting with no configuration on the hAP ac: 1) Define a bridge, add all ports to the bridge. At the terminal command line:
add ports=ether1,ether5 switch=switch1 vlan-id=30
set ether1 vlan-mode=fallback vlan-header=always-strip
set ether5 vlan-mode=secure vlan-header=add-if-missing default-vlan-id=30
I changed ether1 to Fallback mode to access the other devices on hAP ac ether 2-4.
This approach worked for the RB 951, too.
For the CRS125, the commands were slightly different:
In this case the trunk port to my router is Eth 21 and the HA device I want to put on VLAN 30 is on Eth23.
At the Terminal Command line:
interface bridge
add name=bridge1
add bridge=bridge1 interface=ether21 hw=yes
add bridge=bridge1 interface=ether23 hw=yes
/interface ethernet switch ingress-vlan-translation
add ports=ether23 customer-vid=0 new-customer-vid=30
/interface ethernet switch egress-vlan-tag
add tagged-ports=ether21 vlan-id=30
add ports=ether21,ether23 vlan-id=30
The following line is in the Mikrotik examples. Don’t add this if you’re connected to the trunk port (ether21 in my case). You’ll lose your connection. A reminder to never modify the interface you’re connected to. Of course, I did this and lost the connection!
set drop-if-invalid-or-src-port-not-member-of-vlan-on-ports=ether21,ether23
