[solved] Atheros 108Mbps with EoIP?
I have 2 Microtic boxes. Both with atheros based card.
I wont to connect them with 108Mbps but in Winbox there is only 54Mbps!?
The cards are set to 2437..
Help?
Info: Atheros AR5213 (TP-Link card).
Whats is set for band? is it turbo?
am… confused right now…
Yes, there is : 2.4GHz-G-turbo activated but on other side i get only 54Mbps?!
In winbox in Data Rates section i get only 54Mbps (as i read it is normal and will work on 108Mbps on f=2437MHz but it does not)..
Help?
More info:
TP-Link TL-WN651G SuperG 108Mbps
PS. Got Gigabyte GN-WPEAG 108Mbps, 802.11b/g PCI card… Same thing!
Many thanks
It doesent show 108mbit, it still says 54mbit when you use turbo but speed is faster.
you will never get 108Mbits, that is marketing trick. 108Is air rate, not real rate. You can hope for something like 70-80 in ideal conditions.
ok. now i see. Thanks.
I didn’t make G+ connection jet but i’ll try later. Thanks on support
