[Solved ]Can I remove additional USB stick from ROS ?
Hello community,
I have an ALIX board with ROS installed on a CF card.
Then I played around with an additional USB stick plugged in and formatted.
Can I remove this stick after shutting down the ROS ?
Or must I disable the stick in ROS ? I can’t find something !
I didn’t configure the USB stick as webproxy cache or something else !
Greetings
CP
you can remove it, no problems as it is only an additional drive.
