After a configuration reset with no default configuration I am not able to connect to it anymore.
I do know that RB5009 has a default admin password printed on its back and it is not the “usual” empty password.
I have been running successfully WinBox until now, but what is happening now is that it won’t let me in with a “ERR: Could not connect. Mac connect syn timeout”.
I have also tried the reset button for both “backup router boot” (<3 sec) and “reset config” (flashing led).
No way to login, neither with printed password nor with empty one .
Now what? Any hint?
You can’t netinstall the wrong device, device has to be put in netinstall mode for that.
However I’d recommned you to do direct connections … netinstall is a pretty fragile process and you don’t want other traffic (possibly triggering dropped frames in ethernet network) to mess with the process.
