[SOLVED] Can't access PCs, NAS via LAN but via Wifi is OK
I have some problems: made a basic setup of MikroTik 951G-2HnD pppoe works, internet works, but I can’t access
PCs and NAS which I have on my LAN, but I can access them via Wifi.
Port 1 of Mikrotik is connected to ADSL modem, then everything is connected to Mikrotik via LAN: PC1 (fixed IP - 192.168.1.7),PC2 (fixed ip - 192.168.1.8 ),PC3(fixed ip - 192.168.1.9),NAS(fixed ip - 192.168.1.10).
I can ping NAS via LAN but can’t connect to it or access SMB shares, but when I use wifi connection on any PC - I can access NAS or other PCs with no problem. My config is below.
add admin-mac=D4:CA:6D:93:62:55 ageing-time=5m arp=enabled auto-mac=no \
    disabled=no forward-delay=15s l2mtu=1598 max-message-age=20s mtu=1500 \
    name=bridge-local priority=0x8000 protocol-mode=rstp transmit-hold-count=\
    6
set 0 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited \
    disabled=no full-duplex=yes l2mtu=1598 mac-address=D4:CA:6D:93:62:54 \
    master-port=none mtu=1500 name=ether1-gateway speed=100Mbps
set 1 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited \
    disabled=no full-duplex=yes l2mtu=1598 mac-address=D4:CA:6D:93:62:55 \
    master-port=none mtu=1500 name=ether2-master-local speed=100Mbps
set 2 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited \
    disabled=no full-duplex=yes l2mtu=1598 mac-address=D4:CA:6D:93:62:56 \
    master-port=ether2-master-local mtu=1500 name=ether3-slave-local speed=\
    100Mbps
set 3 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited \
    disabled=no full-duplex=yes l2mtu=1598 mac-address=D4:CA:6D:93:62:57 \
    master-port=ether2-master-local mtu=1500 name=ether4-slave-local speed=\
    100Mbps
set 4 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited \
    disabled=no full-duplex=yes l2mtu=1598 mac-address=D4:CA:6D:93:62:58 \
    master-port=ether2-master-local mtu=1500 name=ether5-slave-local speed=\
    100Mbps
/interface ethernet switch
set 0 mirror-source=none mirror-target=none name=switch1
set [ find default=yes ] authentication-types=wpa2-psk eap-methods="" \
    group-ciphers=aes-ccm group-key-update=5m interim-update=0s \
    management-protection=disabled management-protection-key="" mode=\
    dynamic-keys name=default radius-eap-accounting=no radius-mac-accounting=\
    no radius-mac-authentication=no radius-mac-caching=disabled \
    radius-mac-format=XX:XX:XX:XX:XX:XX radius-mac-mode=as-username \
    static-algo-0=none static-algo-1=none static-algo-2=none static-algo-3=\
    none static-key-0="" static-key-1="" static-key-2="" static-key-3="" \
    static-sta-private-algo=none static-sta-private-key="" \
    static-transmit-key=key-0 supplicant-identity=MikroTik tls-certificate=\
    none tls-mode=no-certificates unicast-ciphers=aes-ccm wpa-pre-shared-key=\
     wpa2-pre-shared-key=\
/interface wireless
set 0 adaptive-noise-immunity=none allow-sharedkey=no antenna-gain=0 area="" \
    arp=enabled band=2ghz-b/g basic-rates-a/g=6Mbps basic-rates-b="" \
    bridge-mode=enabled channel-width=20mhz compression=no country=\
    no_country_set default-ap-tx-limit=0 default-authentication=yes \
    default-client-tx-limit=0 default-forwarding=yes dfs-mode=none \
    disable-running-check=no disabled=no disconnect-timeout=3s distance=\
    indoors frame-lifetime=0 frequency=2437 frequency-mode=manual-txpower \
    frequency-offset=0 hide-ssid=yes ht-ampdu-priorities=0 ht-amsdu-limit=\
    8192 ht-amsdu-threshold=8192 ht-basic-mcs=\
    mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7 ht-guard-interval=any \
    ht-rxchains=0,1 ht-supported-mcs="mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-\
    6,mcs-7,mcs-8,mcs-9,mcs-10,mcs-11,mcs-12,mcs-13,mcs-14,mcs-15,mcs-16,mcs-1\
    7,mcs-18,mcs-19,mcs-20,mcs-21,mcs-22,mcs-23" ht-txchains=0,1 \
    hw-fragmentation-threshold=disabled hw-protection-mode=none \
    hw-protection-threshold=0 hw-retries=7 l2mtu=2290 mac-address=\
    D4:CA:6D:93:62:59 max-station-count=2007 mode=ap-bridge mtu=1500 \
    multicast-helper=default name=wlan1 noise-floor-threshold=default \
    nv2-cell-radius=30 nv2-noise-floor-offset=default nv2-preshared-key="" \
    nv2-qos=default nv2-queue-count=2 nv2-security=disabled \
    on-fail-retry-time=100ms periodic-calibration=default \
    periodic-calibration-interval=60 preamble-mode=both \
    proprietary-extensions=post-2.9.25 radio-name=D4CA6D936259 \
    rate-selection=advanced rate-set=configured scan-list=default \
    security-profile=default ssid= station-bridge-clone-mac=\
    00:00:00:00:00:00 supported-rates-a/g=\
    6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps supported-rates-b=\
    "" tdma-period-size=2 tx-power=6 tx-power-mode=card-rates \
    update-stats-interval=disabled wds-cost-range=50-150 wds-default-bridge=\
    none wds-default-cost=100 wds-ignore-ssid=no wds-mode=disabled \
    wireless-protocol=802.11 wmm-support=disabled
/interface wireless manual-tx-power-table
set wlan1 manual-tx-powers="1Mbps:17,2Mbps:17,5.5Mbps:17,11Mbps:17,6Mbps:17,9M\
    bps:17,12Mbps:17,18Mbps:17,24Mbps:17,36Mbps:17,48Mbps:17,54Mbps:17,HT20-0:\
    17,HT20-1:17,HT20-2:17,HT20-3:17,HT20-4:17,HT20-5:17,HT20-6:17,HT20-7:17,H\
    T40-0:17,HT40-1:17,HT40-2:17,HT40-3:17,HT40-4:17,HT40-5:17,HT40-6:17,HT40-\
    7:17"
/interface wireless nstreme
set wlan1 disable-csma=no enable-nstreme=no enable-polling=yes framer-limit=\
    3200 framer-policy=none
/ip hotspot profile
set [ find default=yes ] dns-name="" hotspot-address=0.0.0.0 html-directory=\
    hotspot http-cookie-lifetime=3d http-proxy=0.0.0.0:0 login-by=\
    cookie,http-chap name=default rate-limit="" smtp-server=0.0.0.0 \
    split-user-domain=no use-radius=no
/ip hotspot user profile
set [ find default=yes ] idle-timeout=none keepalive-timeout=2m name=default \
    shared-users=1 status-autorefresh=1m transparent-proxy=no
/ip ipsec proposal
set [ find default=yes ] auth-algorithms=sha1 disabled=no enc-algorithms=3des \
    lifetime=30m name=default pfs-group=modp1024
add name=dhcp_pool1 ranges=192.168.1.30-192.168.1.76
add name=dhcp_pool2 ranges=192.168.1.30-192.168.1.76
add address-pool=dhcp_pool2 authoritative=after-2sec-delay bootp-support=\
    static disabled=no interface=bridge-local lease-time=3d name=dhcp1
/ppp profile
set 0 change-tcp-mss=yes name=default only-one=default use-compression=\
    default use-encryption=default use-mpls=default use-vj-compression=\
    default
set 1 change-tcp-mss=yes name=default-encryption only-one=default \
    use-compression=default use-encryption=yes use-mpls=default \
    use-vj-compression=default
/interface pppoe-client
add ac-name="" add-default-route=yes allow=pap,chap,mschap1,mschap2 \
    dial-on-demand=no disabled=no interface=ether1-gateway max-mru=1480 \
    max-mtu=1480 mrru=disabled name=pppoe-out password= \
    profile=default service-name="" use-peer-dns=yes user=\
/queue type
set 0 kind=pfifo name=default pfifo-limit=50
set 1 kind=pfifo name=ethernet-default pfifo-limit=50
set 2 kind=sfq name=wireless-default sfq-allot=1514 sfq-perturb=5
set 3 kind=red name=synchronous-default red-avg-packet=1000 red-burst=20 \
    red-limit=60 red-max-threshold=50 red-min-threshold=10
set 4 kind=sfq name=hotspot-default sfq-allot=1514 sfq-perturb=5
set 5 kind=none name=only-hardware-queue
set 6 kind=mq-pfifo mq-pfifo-limit=50 name=multi-queue-ethernet-default
set 7 kind=pfifo name=default-small pfifo-limit=10
/routing bgp instance
set default as=65530 client-to-client-reflection=yes disabled=no \
    ignore-as-path-len=no name=default out-filter="" redistribute-connected=\
    no redistribute-ospf=no redistribute-other-bgp=no redistribute-rip=no \
    redistribute-static=no router-id=0.0.0.0 routing-table=""
/routing ospf instance
set [ find default=yes ] disabled=no distribute-default=never in-filter=\
    ospf-in metric-bgp=auto metric-connected=20 metric-default=1 \
    metric-other-ospf=auto metric-rip=20 metric-static=20 name=default \
    out-filter=ospf-out redistribute-bgp=no redistribute-connected=no \
    redistribute-other-ospf=no redistribute-rip=no redistribute-static=no \
    router-id=0.0.0.0
/routing ospf area
set [ find default=yes ] area-id=0.0.0.0 disabled=no instance=default name=\
    backbone type=default
/snmp community
set [ find default=yes ] addresses="" authentication-password="" \
    authentication-protocol=MD5 encryption-password="" encryption-protocol=\
    DES name=public read-access=yes security=none write-access=no
/system logging action
set 0 memory-lines=100 memory-stop-on-full=no name=memory target=memory
set 1 disk-file-count=2 disk-file-name=log disk-lines-per-file=100 \
    disk-stop-on-full=no name=disk target=disk
set 2 name=echo remember=yes target=echo
set 3 bsd-syslog=no name=remote remote-port=514 src-address=0.0.0.0 \
    syslog-facility=daemon syslog-severity=auto target=remote
/user group
set read name=read policy="local,telnet,ssh,reboot,read,test,winbox,password,w\
    eb,sniff,sensitive,api,!ftp,!write,!policy" skin=default
set write name=write policy="local,telnet,ssh,reboot,read,write,test,winbox,pa\
    ssword,web,sniff,sensitive,api,!ftp,!policy" skin=default
set full name=full policy="local,telnet,ssh,ftp,reboot,read,write,policy,test,\
    winbox,password,web,sniff,sensitive,api" skin=default
add bridge=bridge-local disabled=no edge=auto external-fdb=auto horizon=none \
    interface=ether2-master-local path-cost=10 point-to-point=auto priority=\
    0x80
    interface=wlan1 path-cost=10 point-to-point=auto priority=0x80
/interface bridge settings
set use-ip-firewall=no use-ip-firewall-for-pppoe=no use-ip-firewall-for-vlan=\
    no
set 0 vlan-header=leave-as-is vlan-mode=disabled
set 1 vlan-header=leave-as-is vlan-mode=disabled
set 2 vlan-header=leave-as-is vlan-mode=disabled
set 3 vlan-header=leave-as-is vlan-mode=disabled
set 4 vlan-header=leave-as-is vlan-mode=disabled
set 5 vlan-header=leave-as-is vlan-mode=disabled
/interface l2tp-server server
set authentication=pap,chap,mschap1,mschap2 default-profile=\
    default-encryption enabled=no keepalive-timeout=30 max-mru=1460 max-mtu=\
    1460 mrru=disabled
/interface ovpn-server server
set auth=sha1,md5 certificate=none cipher=blowfish128,aes128 default-profile=\
    default enabled=no keepalive-timeout=60 mac-address=FE:42:1E:F3:19:99 \
    max-mtu=1500 mode=ip netmask=24 port=1194 require-client-certificate=no
/interface pptp-server server
set authentication=mschap1,mschap2 default-profile=default-encryption \
    enabled=no keepalive-timeout=30 max-mru=1460 max-mtu=1460 mrru=disabled
/interface sstp-server server
set authentication=pap,chap,mschap1,mschap2 certificate=none default-profile=\
    default enabled=no keepalive-timeout=60 max-mru=1500 max-mtu=1500 mrru=\
    disabled port=443 verify-client-certificate=no
/interface wireless access-list
/interface wireless align
set active-mode=yes audio-max=-20 audio-min=-100 audio-monitor=\
    00:00:00:00:00:00 filter-mac=00:00:00:00:00:00 frame-size=300 \
    frames-per-second=25 receive-all=no ssid-all=no
/interface wireless sniffer
set channel-time=200ms file-limit=10 file-name="" memory-limit=10 \
    multiple-channels=no only-headers=no receive-errors=no streaming-enabled=\
    no streaming-max-rate=0 streaming-server=0.0.0.0
/interface wireless snooper
set channel-time=200ms multiple-channels=yes receive-errors=no
/ip accounting
set account-local-traffic=no enabled=no threshold=256
/ip accounting web-access
set accessible-via-web=no address=0.0.0.0/0
add address=192.168.1.1/24 comment="default configuration" disabled=no \
    interface=wlan1 network=192.168.1.0
/ip dhcp-client
add add-default-route=yes comment="default configuration" \
    default-route-distance=1 disabled=yes interface=ether1-gateway \
    use-peer-dns=yes use-peer-ntp=yes
/ip dhcp-server config
set store-leases-disk=5m
add address=192.168.1.0/24 dhcp-option="" dns-server="" gateway=192.168.1.1 \
    ntp-server="" wins-server=""
set allow-remote-requests=yes cache-max-ttl=1w cache-size=2048KiB \
    max-udp-packet-size=4096 servers=8.8.8.8
/ip dns static
add address=192.168.88.1 disabled=no name=router ttl=1d
set enabled=yes generic-timeout=10m icmp-timeout=10s tcp-close-timeout=10s \
    tcp-close-wait-timeout=10s tcp-established-timeout=1d \
    tcp-fin-wait-timeout=10s tcp-last-ack-timeout=10s \
    tcp-syn-received-timeout=5s tcp-syn-sent-timeout=5s tcp-syncookie=no \
    tcp-time-wait-timeout=10s udp-stream-timeout=3m udp-timeout=10s
add action=accept chain=input comment="Added by webbox" disabled=no protocol=\
    icmp
add action=accept chain=input comment="Added by webbox" connection-state=\
    established disabled=no in-interface=pppoe-out
    related disabled=no in-interface=pppoe-out
add action=drop chain=input comment="Added by webbox" disabled=no \
add action=jump chain=forward comment="Added by webbox" disabled=no \
    in-interface=pppoe-out jump-target=customer
add action=accept chain=customer comment="Added by webbox" connection-state=\
    related disabled=no
add action=drop chain=customer comment="Added by webbox" disabled=no
add action=masquerade chain=srcnat comment="Added by webbox" disabled=no \
    out-interface=pppoe-out
/ip firewall service-port
set ftp disabled=no ports=21
set tftp disabled=no ports=69
set irc disabled=no ports=6667
set h323 disabled=no
set sip disabled=no ports=5060,5061 sip-direct-media=yes
set pptp disabled=no
/ip hotspot service-port
/ip neighbor discovery
set ether1-gateway disabled=yes
set ether2-master-local disabled=no
set ether3-slave-local disabled=no
set ether4-slave-local disabled=no
set ether5-slave-local disabled=no
set wlan1 disabled=yes
set bridge-local disabled=no
set pppoe-out disabled=yes
/ip proxy
set always-from-cache=no cache-administrator=webmaster cache-hit-dscp=4 \
    cache-on-disk=no enabled=no max-cache-size=unlimited \
    max-client-connections=600 max-fresh-time=3d max-server-connections=600 \
    parent-proxy=0.0.0.0 parent-proxy-port=0 port=8080 serialize-connections=\
    no src-address=0.0.0.0
/ip service
set telnet address="" disabled=no port=23
set ftp address="" disabled=no port=21
set www address="" disabled=no port=80
set ssh address="" disabled=no port=22
set www-ssl address="" certificate=none disabled=yes port=443
set api address="" disabled=yes port=8728
set winbox address="" disabled=no port=8291
/ip smb
set allow-guests=yes comment=MikrotikSMB domain=MSHOME enabled=no interfaces=\
    all
/ip smb shares
set [ find default=yes ] comment="default share" directory=/pub disabled=no \
    max-sessions=10 name=pub
/ip smb users
set [ find default=yes ] disabled=no name=guest password="" read-only=yes
/ip socks
set connection-idle-timeout=2m enabled=no max-connections=200 port=1080
/ip traffic-flow
set active-flow-timeout=30m cache-entries=4k enabled=no \
    inactive-flow-timeout=15s interfaces=all
/ip upnp
set allow-disable-external-interface=no enabled=yes show-dummy-rule=yes
/ip upnp interfaces
add disabled=no interface=ether1-gateway type=internal
add disabled=no interface=ether2-master-local type=internal
add disabled=no interface=ether3-slave-local type=internal
add disabled=no interface=ether4-slave-local type=internal
add disabled=no interface=ether5-slave-local type=internal
add disabled=no interface=wlan1 type=internal
add disabled=no interface=bridge-local type=internal
add disabled=no interface=pppoe-out type=external
/mpls
set dynamic-label-range=16-1048575 propagate-ttl=yes
/mpls interface
set [ find default=yes ] disabled=no interface=all mpls-mtu=1508
/mpls ldp
set distribute-for-default-route=no enabled=no hop-limit=255 loop-detect=no \
    lsr-id=0.0.0.0 path-vector-limit=255 transport-address=0.0.0.0 \
    use-explicit-null=no
/port firmware
set directory=firmware ignore-directip-modem=no
/ppp aaa
set accounting=yes interim-update=0s use-radius=no
/queue interface
set ether1-gateway queue=only-hardware-queue
set ether2-master-local queue=only-hardware-queue
set ether3-slave-local queue=only-hardware-queue
set ether4-slave-local queue=only-hardware-queue
set ether5-slave-local queue=only-hardware-queue
set wlan1 queue=wireless-default
/radius incoming
set accept=no port=3799
/routing bfd interface
set [ find default=yes ] disabled=no interface=all interval=0.2s min-rx=0.2s \
    multiplier=5
/routing mme
set bidirectional-timeout=2 gateway-class=none gateway-keepalive=1m \
    gateway-selection=no-gateway origination-interval=5s preferred-gateway=\
    0.0.0.0 timeout=1m ttl=50
/routing rip
set distribute-default=never garbage-timer=2m metric-bgp=1 metric-connected=1 \
    metric-default=1 metric-ospf=1 metric-static=1 redistribute-bgp=no \
    redistribute-connected=no redistribute-ospf=no redistribute-static=no \
    routing-table=main timeout-timer=3m update-timer=30s
/snmp
set contact="" enabled=no engine-id="" location="" trap-generators="" \
    trap-target="" trap-version=1
/system clock
set time-zone-name=
/system clock manual
set dst-delta=+00:00 dst-end="jan/01/1970 00:00:00" dst-start=\
    "jan/01/1970 00:00:00" time-zone=+00:00
/system identity
set name=MikroTik
/system leds
set 0 disabled=no interface=wlan1 leds=wlan-led type=wireless-status
/system logging
set 0 action=memory disabled=no prefix="" topics=info
set 1 action=memory disabled=no prefix="" topics=error
set 2 action=memory disabled=no prefix="" topics=warning
set 3 action=echo disabled=no prefix="" topics=critical
/system note
set note="" show-at-login=yes
/system ntp client
set enabled=yes mode=unicast primary-ntp=79.142.192.4 secondary-ntp=\
    91.236.251.5
/system resource irq
set 0 cpu=auto
set 1 cpu=auto
set 2 cpu=auto
set 3 cpu=auto
/system routerboard settings
set boot-device=nand-if-fail-then-ethernet boot-protocol=bootp cpu-frequency=\
    600MHz force-backup-booter=no silent-boot=no
/system upgrade mirror
set check-interval=1d enabled=no primary-server=0.0.0.0 secondary-server=\
    0.0.0.0 user=""
/system watchdog
set auto-send-supout=no automatic-supout=yes no-ping-delay=5m watch-address=\
    none watchdog-timer=yes
/tool bandwidth-server
set allocate-udp-ports-from=2000 authenticate=yes enabled=yes max-sessions=\
    100
/tool e-mail
set address=0.0.0.0 from=<> password="" port=25 starttls=no user=""
/tool graphing
set page-refresh=300 store-every=5min
/tool mac-server
set [ find default=yes ] disabled=yes interface=all
/tool mac-server mac-winbox
/tool mac-server ping
set enabled=yes
/tool sms
set allowed-number="" channel=0 keep-max-sms=0 receive-enabled=no secret=""
/tool sniffer
set file-limit=1000KiB file-name="" filter-ip-address="" filter-ip-protocol=\
    "" filter-mac-address="" filter-mac-protocol="" filter-port="" \
    filter-stream=yes interface=all memory-limit=100KiB memory-scroll=yes \
    only-headers=no streaming-enabled=no streaming-server=0.0.0.0
/tool traffic-generator
set latency-distribution-scale=10 test-id=0
/user aaa
set accounting=yes default-group=read exclude-groups="" interim-update=0s \
    use-radius=no
You have created two bridges and assigned one port only (ether2, as master of 3,4,5) to the first, and wlan1 to the other.
Only wlan1 does have an IP address, so no routing from the ethernet port bridge.
I suggest you remove one bridge, put both ether2 and wlan into that bridge, and assign one DHCP server to it.
Also remove one of the two IP pools for serving the same subnet.
could you also please show us
/export compactfor better readiness.
[edit]
After reading your config again, I found that you did not create two bridges, so everything looked ok.
Only comment is the two IP pools, but that can not do any harm.
Maybe it has something to do with DNS?
Or, just for testing, what happens if you add al the ether ports into the bridge, and do not use master-port setting?
[/edit]
I have RouterOS 5.25 installed. Have used the default config RouterOS offers as base settings.
Not sure if it has something to do with DNS, internet via pppoe works OK when on LAN or WLAN with all devices I have.
Did it - no changes.
Not able to connect via SMB or HTTP but still able to ping. Strange.
add admin-mac=D4:CA:6D:93:62:55 auto-mac=no l2mtu=1598 name=bridge-local \
    protocol-mode=rstp
/interface wireless
set 0 band=2ghz-b/g basic-rates-b="" bridge-mode=disabled disabled=no distance=\
    indoors frequency=2437 hide-ssid=yes ht-rxchains=0,1 ht-txchains=0,1 l2mtu=\
    2290 mode=ap-bridge rate-set=configured ssid=Rampard supported-rates-b="" \
set 0 name=ether1-gateway
set 1 name=ether2-master-local
set 2 master-port=ether2-master-local name=ether3-slave-local
set 3 master-port=ether2-master-local name=ether4-slave-local
set 4 master-port=ether2-master-local name=ether5-slave-local
add add-default-route=yes disabled=no interface=ether1-gateway name=\
    pppoe-out password= use-peer-dns=yes user=\
set wlan1 enable-polling=no
set [ find default=yes ] authentication-types=wpa2-psk eap-methods=passthrough \
    mode=dynamic-keys wpa-pre-shared-key= wpa2-pre-shared-key=\
add address-pool=dhcp_pool2 disabled=no interface=bridge-local name=dhcp1
add bridge=bridge-local interface=ether2-master-local
add bridge=bridge-local interface=wlan1
add interface=wlan1 mac-address=
add address=192.168.1.1/24 comment="default configuration" interface=\
    bridge-local
/ip dhcp-client
add comment="default configuration" interface=ether1-gateway
add address=192.168.1.0/24 gateway=192.168.1.1
set allow-remote-requests=yes servers=,
/ip dns static
add address=192.168.88.1 name=router
add chain=input comment="Added by webbox" protocol=icmp
add chain=input comment="Added by webbox" connection-state=established \
add chain=input comment="Added by webbox" connection-state=related \
add action=drop chain=input comment="Added by webbox" in-interface=\
    pppoe-out
add action=jump chain=forward comment="Added by webbox" in-interface=\
add chain=customer comment="Added by webbox" connection-state=established
add chain=customer comment="Added by webbox" connection-state=related
add action=masquerade chain=srcnat comment="Added by webbox" out-interface=\
    pppoe-out to-addresses=0.0.0.0
/ip upnp
/ip upnp interfaces
add interface=ether1-gateway type=internal
add interface=ether2-master-local type=internal
add interface=ether3-slave-local type=internal
add interface=ether4-slave-local type=internal
add interface=ether5-slave-local type=internal
add interface=wlan1 type=internal
add interface=bridge-local type=internal
add interface=pppoe-out type=external
/system clock
set time-zone-name=Europe
/system leds
set 0 interface=wlan1
/system ntp client
    91.236.251.5
/tool mac-server
add interface=wlan1
Sounds very strange. Almost think that it has something to do with the NAS itself.
What if you connect directly or with plain switch?
NAS is connected directly to MikroTik and I use a NAS already for more than 6 months on the same LAN before it was connected to a simple 5-port GLAN switch and ADSL modem (Zyxel) was acting as the router. Very strange, because I can access NAS SMB shares via LAN for several seconds and then i can’t do it anymore. :open_mouth:
Firewall was disabled of course. Will check it with Mac connected to my LAN.
Have checked many times: connect everything via a simple GLAN switch (and ADSL modem as router) - everything works, connect everything via MikroTik - NAS not accessible. :frowning:
I’ve just checked with iMac connected via GLAN to MikroTik - everything works fine! Very strange issue with Win7 (tried with 2 different PCs!) and access to a NAS made by Synology. Can’t fix it at the moment. But why does it work well when the NAS is connected to a GLAN switch :open_mouth: The same network, the same computers and NAS, only one thing is different is MikroTik router.
P.S. Any idea how I can check how packets are going to NAS? Tracert shows no problem. Did route -f - no changes. When NAS is accessed by client connected via LAN - not working, the same client but accesses via WLAN or via iMac - works well.
The solution:
NAS MTU is set to 9000, PC1, PC2 MTU was also set to 9000, wifi MTU was default - 1500, iMac MTU was also default - 1500.
Have changed PCs MTUs to default - everything works FINE!!! Now need to change MTU in MikroTik to 9000 so I can speed up my GLAN. How to do it? Manually can’t make it 9000.
It depends on your hardware (MT version) what’s your max MTU.
I have an 2011 and the max MTU is somewhere around 4092.
I had tried before to fool around with the MTU but could not find a proper config. I don’t understand MTU values agtetall I guess.
I use MikroTik 951G-2HnD and Max MTU for it is 4074 :frowning: Strange. My simple GLAN switch has Large MTU support by default e.g. 9k. So what to do with NAS? It has 9k MTU now and it reduces CPU load for it.
P.S. Strange that with 9k MTU setting in PCs and NAS these devices have working internet connection but problems inside of LAN.
