Export your config.
Do a netinstall with new RouterOS.
Import your config.
If this device is mission critical, try this at first with a spare device to ensure the exported configuration works flawlessly with the new RouterOS version.
Did you upload the new packages via Winbox/FTP or did you used “Check for updates” button?
Normally uploading the .npk-File and rebooting the device does the trick.
Sorry for asking this dumb question, but did you use the right npk-file for the CCR’s system architecture (I think it’s tile)?
You can enable debug logging in “/system logging”, maybe you’ll get told what’s wrong.
I used the “check for updates” button, and “download and upgrade” then.
I will try to manually upload the (right) .npk files, and let you know what happens
I removed the .npk I previously uploaded, leaving the disk without any NPK.
And then, I made the “check for updates” + “download&upgrade” process from /system packages, and everything worked.
Please prefix the title of your first post with “[solved]”, so other people looking for a similar problem can see at a glance that this thread describes an approved solution. Thank you!
Sorry to bring this Topic on to again.
I just had a similar Problem. But my CCR didn’t reboot when I clicked on “Reboot”, so an upgrade wasn’t possible. Upgrading via “check for updates” did a proper reboot so the upgrade worked.
Are you sure that your CCR did a reboot? I just want to find out if it may be a bug or if my CCR is just crazy.
